Page 80 of 243 FirstFirst ... 3070757677787980818283848590130180 ... LastLast
Results 1,186 to 1,200 of 3633
Thread: MPPS
  1. #1186
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    @mihaiservice
    You seems to be lucky, because a lot people try to update 41323234 and all they get is: ECU Not Found.
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  2. #1187
    mihaiservice's Avatar
    Dec 2009
    http://www.quick-tuning.com
    maybe
    anyone it know wich sw are the last ? or someone make jokes about last sw
  3. #1188
    Jun 2009
    4.0.1.9 is latest.
  4. #1189
    Sep 2009
    Norway
    But do anyone sell clone that is working with 4.0.1.9 ?
    BR
    KP
  5. #1190
    Harrycz44
    Guest
    EDC16C31 with 3.0.2.31 flashing data 1344 kB and with
    3.0.2.37 1920kB?
    Software problem?
  6. #1191
    Sep 2009
    Norway
    Quote Originally Posted by Harrycz44 View Post
    3.0.2.37 1920kB?
    Software problem?
    Complete read should be 2 mb.
    BR
    KP
  7. #1192
    moky's Avatar
    Apr 2010
    Behind you
    Quote Originally Posted by kptuning View Post
    nobody actually ...only fake,be carefull
  8. #1193
    Nov 2009
    South Africa
    good day all. i have purchased mpps v 3.0.2.38. i have diconnected the antivirus. installed the software. tried to read 3 gti golf 5's...1 T5 2.5 bus... 1 golf4 gti... i cant seem to wake up the ecu. the gti's are med9.1's..they are listed. to install the program is fairly easy. how would i know if it is a software problem or a hardware issue. thanks members.
  9. #1194
    DK Veteran rappttor's Avatar
    Apr 2010
    PERPETUUM MOBILE
    post a print screen with your mpps sofware, and cable inserted in ths usb port
  10. #1195
    Sep 2009
    Norway
    Quote Originally Posted by moky View Post
    Just like i belived, but is this a hw problem or could this be fixed with a proper crack?
    BR
    KP
  11. #1196
    DK Veteran rsibiza's Avatar
    Quote Originally Posted by frikki View Post
    MPPS 3.0.2.37 is last working version...if blacklist serials are mod in ini file they no more recognised as clone and dont show FFFFFFFF...but dont wake up any ecu
    This is explained lot of times,you are not the first and not the last...which will encounter this phenomen..
  12. #1197
    Nov 2009
    South Africa
    thanks rsibiza. should i then load the 2.0.2.37 version. i was told by my supplier to load the 2.0.2.37. thanks.
  13. #1198
    Nov 2009
    South Africa
    sorry i was told to load the 38. tried reinstall version 37. no luck, tried waking up golf5 edc 16 u1. not communicating.
  14. #1199
    May 2010
    Moon
    if 3.0.2.37 is not working you have bricked it and needs to be reflashed
  15. #1200
    Nov 2009
    South Africa
    thanks bazare. how do one do that. will i be able to do it myself. do you also use bdm100. will clone work on med9.1 ecu. do i need to remove the ecu and open it up to read the flash. thanks.
