Results 1 to 3 of 3
    May 2022
    Default Mercedes B180 W245 ignition problem
    Hello everyone,
    When I put the key in neiman, it turns but steering column does not unlock, the dashboard does not light up.
    I can access EZS and ELV with diagnostic tools, the key is recognized in EZS. But ELV does not receive the opening command.
    How can i fix ELV if ELV is faulty? Or how can i check if EZS if faulty and not sending signal to ELV while the keys are well recognized?
    I have xprog, can i flash ELV and EZS data to try fix?
    Thank you very much
    Feb 2018
    Very possible reason is mechanical broke in sterring lock, broken electric engine in sterring lock modul.
    peko's Avatar
    hi friend
    i have exactly same problem
    ezs reply to diag
    key is programmed
    but when you turn ignition to ON in ezs, nothing ligth on ... dash stay off and engine not cranck ... nothing
    via obd no way to check esl , esl seem not receive information from ezs
    have you solved it ?
