Results 1 to 15 of 18
Thread: football
    V.I.P. Member thered's Avatar
    Aug 2008
    Default football
    footy tonight desperate here
    united v w ham
    its on
    diema...... 39e 16e and 0.8 west
    g sport 2 ....36,9 and 7 east
    hi soccer.... 36 east
    show sport 3.... 7 west
    yes ..... 4 west
    sport tv 1.... 30 west
    problem is i cant seem to find any of these channels i understand show sport @7 west is too far away for my dish but what about the rest
    i have a 1.1m dish should these channels be on or what i have searched and cant find any not even on thor or 16 east
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Check liveonsat.com and that will tell you what frequency and transponder they're on. You can then do a manual scan if they're not already in your list. Chances are they're not on hacked packages and you'll need to be a subscriber to see them. Unless you're on CS.
    Aug 2008
    no no cs not yet anyways
    the problem is the channels are not there at all in my channel lists or i cant get the satellite
    i was assuming they should be(well at least 0.8 west and 16 east)in with the rest of the channels i have scanned a couple of times
    so basically can anyone confirm the channels listed previously in the first post are gettable or not
    kick off 8;00 cmon dkers your country needs you
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    0.8w and 16e should be achievable with a 1.1mtr dish in the UK.
    Pick the channel on 16e, find the frequency and transponder etc from liveonsat or en.kingofsat.net.
    Go to the motor control page on the dreambox and go to 16e.
    Click on the dropdown box and select the right beam.
    You will see the SNR %. If you're hitting the beam it should be greater than 70%.
    If not, try jogging the motor left for a bit then right for a bit to see if it improves the SNR.
    If it does, store the new position for 16e. If it doesn't looks like the dish is out of alignment.
    But if you get 13e and 19e you should be able to get 16e.
    Aug 2008
    this i have tried i seem to get a full channel list on thor and 16 east but for some reason i cant find the channel listed on lj's maybe its just missing the transponder il keep playig though cheers df
    Aug 2008
    Tamworth UK
    Aug 2008
    thanks m8 but its not the same
    Aug 2008
    Tamworth UK
    stick it up ya arris then!!! really! some people!
    V.I.P. Member Curious123's Avatar
    Apr 2008
    Bring up your bouquets than press green to select the satellites than select 16.0E and than select services. You should see an alpahbetical list of channels including couple of the diema channels. I have a 1m dish and I am picking up most of the channels on 16.0E
    Aug 2008
    i am just rescanning 16 east now i will let you know when its finished im sure it was there before
    can you get diema on thor 0,8 though cos i have scanned that again to no avail
    by the way curious can you clear diema do you know or is it only c/s
    Aug 2008
    just to confirm i now have diema on 16 east i cant find on 0.8 though anyone verify should i have it
    only thing its encrypted f**kers il try the latest keys
    if anyone else knows where i can get it please join in thanks very much
    Apr 2008
    I can see diema on 39.0E Bulsatcom and on 16.0E but can't see it on 0.8W Thor. It is open for me on 39E and 16E but if I take out my network cable from my dreambox than it freezes so it is probably only open via c/s.
  13. #13
    Aug 2008
    thanks m8 looks like im running out of options il try the latest keys and see if it helps il keep you posted at least i know im not cracking up it says on ljs football that is on thor though
    anyone add any info countdown to kickoff is not far away
  14. #14
    Aug 2008
    yeh your right curious its encrypted just tried the latest keys no joy f**k f**k f**k
    looks like im running out of time god i hate encryption
    theres still time though can someone pull it out of the bag and tell me where i can watch united west ham tonight without c/s
    please dkrs
  15. #15
    Aug 2008
    Tamworth UK
    i've already told you, but you chose to cock a snook at me, so
