Originally Posted by
pisilva
Hi all,
My daughter recently bought an Opel Corsa D 1.3 CDTI Ecoflex from 2008.
This was a car that has been stopped for a while, so a big revision was made on it to make sure all is well.
Some problems were corrected, but the radio did not work. It does not turn on.
The mecanics that work on car the believe it was working, but are not sure. The battery was disconected on the car since he was stooped for while when in maintenance.
The radio is original (radio A) on the car and we have the security code for it. I've dumped the eeprom and checked with OSCR and the code checks out with the one on the Opel Pass Card.
Nevertheless, a used radio (radio B) was put on the car by the person that sold us the car, but he does not have the code so the Display Safe is on.
So, my questions for you more guys more used to this issues:
Any idea why radio A stopped turning on. Radio B works, so, it seems that its not a car fuse issue. Th fuse on the radio seems to be OK.
If I exchange the fronts panels form radio B to radio A, will it make any diference? Is it worth to try?
Since I have the code for radio A and the dump, if I load it on radio B's EEPROM, will it work? Will the Display consider that radio B is the original radio?
What other options do I have? Any suggestions?
Thanks for your help.
Best regards.
Pedro
