Results 1 to 2 of 2
    Aug 2021
    Default Atmega 64A reading problem
    Hi,please need help to read atmega 64a from xprog v6.12 pcb(wait for certificate)
    I try to read with upa v1.3(clone) and xgecu t56 everything 0000
    I use those two schematic diagram below
    Thanks in advance
    Mar 2021
    Default xprog reprogram
    i did mine using vvdi prog read and save config then click unlock chip that will unlock and erase it right flash and eeprom then right config back that will then lock the chip again
