Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    AS mentioned previously pull up the carpet and sound deadening in the drivers footwell underneath you will find some wiring and multi plugs check it is not wet or corroded it is a common problem on a 406 and can cause your symptoms.
  2. #17
    mexanico1971's Avatar
    portugal
    Quote Originally Posted by mecanodiag View Post
    Greetings and thank you all for your response I redo a new control with the diag PP2000, there is still no communication between the BSI and the ECM, the ECM does not answer, I checked all the fuses and the 2 cable that communicates between the BSI and ECM
    The BSI is locked and the ECM again how to unlock the BSI?
    I would test another BSI can you tell me how because I am a newbie
    So !
    did you died on the beach ?
    Brs
    My work is my life ART TECH GARAGE
