any news???
KIA Shuma 1.5 L DOHC engine 1998
ECM Siemens K103735112A K2AC
MCU TMS374, EPROM 28F512
I need solution for "im*o off" because im*obilizer forget keys every time after turn off engine
I try many clock files for 28f512 ->
I try to read TMS374 with X-Prog M ->
I get out from board and try to read TMS374 with ETL TMS programmer ->
I
Any solution for this car?
any news???
USE THIS FILE FOR 28F512 ITS IMMO OFF CUT ECU PIN NUMBER 6,DISCONECT IMMOBOX FROM CAR
AND ONE MORE THING YOU HAVE TO FIX ENGINE BLOWER WITH A MANUAL THERMOVALVE CAUSE ITS GOING TO RUN AT ALL TIMES AFTER THE USE OF THIS FILE
Damsterius (12th August, 2013), dEONBE (1st March, 2022), Elektrik001 (2nd September, 2020), Hayssam1 (21st January, 2015), nick_f (2nd December, 2013), NORSHAN (13th January, 2019)
Thank you!!!!
I will try today
Thank you very, very much!!!!!
Work like you say!
Also here is a 1999 Hyundai Lantra 1.6.16V
ECU: 39100-23746 39110-23746 HEI H103955555A Ecu of the same, so I pull 28F512 flash reprogram the Clock and the ladies in the car and do a loop for 1 minute. Then coming back the original content and it will go to start? Immo pin is also at pin 6. ? Please practice or guidance on how to do it?
So I programmed the clock files for 28f512 and gasoline pump OK, but not start Hyndai Lantra 1.6 16V 1996 years.
SHUMA DOHC SIEMENS K103735112 B 28F512 IMMO OFF CKSM EA77.rar (26.6 KB, 194 views)
Immo box is disconnected !
I do not know what I'm doing wrong here when a colleague tried
and it worked OK! Can anyone help ?
NO not ! http://pl112637826.trustpass.alibaba...ATOR_IMMO.html
Yes indeed solved dump operation, I had a bad tin plate brazed ceramic transistor in the spark. Because I changed the transistors and ceramics to be another ECU.
Friend how did you solve the problem? can you help me I have the same problem as you
