Results 1 to 11 of 11
    Mar 2018
    UK
    Default Doblo 2010 remote problem
    Doblo 2010 but still id48 with separate remote
    I programmed 2 second hand remotes with 1 button with SmartPro and the car accept them but the procedure end with fail
    when I go on live data every time when I press some of the remotes its change the remote ID so the car see both of them
    I programmed the remotes with the immo pin code but maybe this one need separate pin for the remotes as old Ducato
    or maybe I'm missing something else
    Ecuprog31's Avatar
    Mar 2018
    Doblo 2010 it’s 2 or 3 button remote
    same as nemo / bipper
    I think 1 button end on 2005 year
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Pin is the same for remote and immo part.
  4. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    Manta1600 (20th April, 2025), samsunguser1001 (28th April, 2025)
    Apr 2022
    Germany
    If you have other tool that can also learn remote, try it.
    Did had Alfa 147 the other day and with MES was OK.
    Other tools could not do the job…
  6. The Following User Says Thank You to wuza For This Useful Post:
  7. #5
    pepi's Avatar
    Jan 2010
    Last time I did the job with Avdi at this brand.
  8. The Following User Says Thank You to pepi For This Useful Post:
  9. #6
    Mar 2018
    UK
    Quote Originally Posted by Ecuprog31 View Post
    Nemo and Bipper use id46 never saw with id48
  10. #7
    Mar 2018
    UK
    Quote Originally Posted by wuza View Post
    Tried also Autel without success
  11. #8
    Mar 2018
    UK
    will try it
  12. #9
    Faraday's Avatar
    May 2012
    MES work ok with this car. Are you sure that this car is equipped with remote control. This might be coding problem.
  13. #10
    Mar 2018
    UK
    Quote Originally Posted by Faraday View Post
    for sure is with remote as there is not lock on the passenger door
    also live data show that there is already programmed one remote and show the ID of the remotes when I press some of them
    I don't have MES but will download the free version to see what can do
  14. #11
    Mar 2018
    UK
    So today I fail also with AVDI and with MES
    and remembered that I read something about this in the past in this thread
    https://www.digital-kaos.co.uk/forum...te-key-for-car
    looks like the remote is synchronised with the chip as on the old Renault PSA with separate chip
    and if you don't have new dealer remote key you can't program remote
    the good news is that on the live data on the SP you can see the remote ID and don't need the BCM from the car that the remote come to read it
  15. The Following 2 Users Say Thank You to Manta1600 For This Useful Post:
    Faraday (22nd April, 2025), lion0304 (23rd April, 2025)
