Results 1 to 5 of 5
    Mar 2011
    Poland
    Default CITROEN NEMO 1.3 DPF OFF , EGR OFF
    HELLO MEMBER .
    PLEASE HELP ME DPF OFF EGR OFF
    CITROEN NEMO 1.3 DIESEL
    51880759
    9743F187
    MJ8DFHW00P
    shendlaw's Avatar
    Jan 2022
    0x086
    Quote Originally Posted by korek516 View Post
    HELLO MEMBER .
    51880759
    9743F187
    MJ8DFHW00P
    hi perform all dpf resets before writing and disconnect differential pressure sensor, enjoy
    Press thanks and rep button if i helped you
    TELEGRAM: @CRCHIPTUNING
    TDI FOREVER
  3. The Following User Says Thank You to shendlaw For This Useful Post:
    korek516 (7th April, 2023)
    Mar 2011
    Poland
    Hello, does anyone else have a solution. DPF is still burned out
    Oct 2021
    Serbia
    perform dpf and oil service reset on ori file, then write mod file and disconnect differential sensor. Thanks + rep
  6. The Following User Says Thank You to LukaLP For This Useful Post:
    korek516 (14th April, 2023)
  7. #5
    Luigi84's Avatar
    Dec 2022
    Italy
    Do a forced regeneration with original file. after that you can write dpf off.
