Page 1 of 2 12 LastLast
Results 1 to 15 of 23
    Default Vectra C Airbag B1000 error
    Hi, one friend have an Opel Vectra C (ModelYear 2002) with airbag light on.
    OP-COM says:
    OP-COM 081016  - PC based diagnostic tool
    OP-COM - CAN Communicaton  Window> 2002|Vectra-C / Signum|Body|SDM (Airbag)
    Read  Info...
    Identifier: 0x0001
    Part Number:13118804
    Software  version number: 00BA845C
    System description: DELCO0400
    Alpha code:  AQ
    Manufacturing date: 020308
    Total number of fault  codes:  1
    B1000 - Replace Electronic Control Unit (ECU)
    (00)  -  Present
    Can I use airbag resetter (clip) to clear SDM-ecu?
    Thanks in advance.
    P.D.: Car don?t have any crash.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    Use OPCOM090821d and use function Clear Deployment Data. Maybe this will work.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    Thanks, i will try this.
    DK Veteran wizz2c's Avatar
    Dec 2009
    earth
    Quote Originally Posted by djbill View Post
    just crash data stored by the looks of things, you can erase with opcom
    Dont forget to say if i helped.
    what do you think about this error (B1000) on airbag ecu?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    i thought to clear crashed data from the module which normally locks you need to do it via the chip on the board not obd connection
    Jose19's Avatar
    Nov 2009
    From the HELL
    Quote Originally Posted by teerak2uk View Post
    Yes , you are correct!!
    Read dump file
    Jose
    z786's Avatar
    Aug 2009
    10 Steps Ahead of You
    you can clear most of the vauxhalls with op-com via obd
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Dec 2009
    hello
    do you have solve the b1000 problem, i have the same
    best regards
    No, sorry.
    You need flash clear crash file on chip. Maybe Airbag resetter will work but i don't know.
    Regards.
  11. #11
    Shmortz's Avatar
    Apr 2010
    in the middle of nowhere
    Hi, I have the same problem, there is also error on other modules that is no connection with airbag module, after clearing the dump of 95040 airbag light goes out for some seconds and then back on, in the time that the light is not on the diagnostic connection is possible, after that module dies again, when turn ACC off and on again in a minute or two the module lives again for some seconds and dies...
    I need full flash of the processor 0K75F (912D60) to compare with my one
  12. #12
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by Shmortz View Post
    what is the part number from the module
  13. #13
    Shmortz's Avatar
    Apr 2010
    13129843 CL
  14. #14
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    13129843 CL
    Try this one
  15. #15
    Shmortz's Avatar
    Apr 2010
    thanks but I don't need this, already tested with good dump for 95040, I think the problem is in processor that's why I want to compare the full flash for motorola with good one...
