Results 1 to 8 of 8
    Newmotors's Avatar
    May 2019
    brazil
    Default Long coding Abs VW
    I need long coding MK60 ABS Vw gol do brazil vin:9BWAG45U1MT088182
    PART NUMBER : 5u0614117
    rafal's Avatar
    UK - PL
    in vcds should be coding helper - checked ?
    need help
    now my goal is to buy xp-005
    who will help?
  3. The Following User Says Thank You to rafal For This Useful Post:
    brend (26th April, 2023)
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by rafal View Post
    In here long coding and not all bit is decoded .
    Best option without play with time online.
    Or genuine last generation universal with....... pasthrue/smartlink/smartbox ....... tool like launch or same another similar tool which work online away ..... NB! CLON CRAP CAN'T DO THIS !
  5. The Following User Says Thank You to brend For This Useful Post:
    rafal (26th April, 2023)
  6. #4
    Jul 2016
    Vilnius
    Contact me and I will calculate the coding for you. VCDS autoscan will be needed
    * MK100
    Newmotors's Avatar
    May 2019
    brazil
    with genuine vcds I don't have the help
    Address 03: ABS Brakes
    Control Module Part Number: 5U0 614 117 M
    Component and/or Version: EBC 460 ABS H04 0130
    Software Coding: 00000000000000000000000000000000000000
    Work Shop Code: WSC 00000
    VCID: 3B23337363EEA1621A9-806E
    Advanced Identification/FAZIT
    Serial number: ADXK627
    Identification: K03-2BV
    Date: 11.18.20
    Manufacturer number: 0001
    Test stand number: 0406
    Flash Status
    Programming Attempts(application): 0/0/0
    Flash Date: 20.11.18
    Misc.
    Hardware number: 5U0 614 117M
    Workshop System Name: J104
    Equipment/PR Code: 000000000000000000000096
    Dataset Number: -----------
    Dataset Version: ----
    ASAM Dataset: EV_Brake1ABSVWB23XTRW
    ASAM Dataset Revision: 001010
    VCDS Info:
    Labels: None
    ROD: EV_Brake1ABSVWB23XTRW_VW23.rod
  8. #6
    Jul 2016
    Vilnius
    Bro, I need FULL autoscan, not just ABS unit...
    * MK100
  9. #7
    brend's Avatar
    Oct 2015
    Same where
    Look like ...... the end ?
    Online ?
  10. #8
    Jul 2016
    Vilnius
    Looks like he doesn't need it as much as it looked like.
    If he really needs, he knows what to do
    * MK100
  11. The Following User Says Thank You to hid3 For This Useful Post:
    brend (28th April, 2023)
