Results 1 to 15 of 15
Thread: menu 8281
    Default menu 8281
    hi can anybody tell me how to get this menu open i have tried puting in 8281 on the romote put nothing happens i have put in software 716 do i need to do foctory resat after also can somebody advise to to save my setting
    Oct 2008
    Default 8281
    Quote Originally Posted by jsgola123 View Post
    you`ve not said which technomate you have.
    mine is the hd6800 and the pw is 0000 to factory reset
    Default menu 8281
    i have the technomate 6900 super just want to know how to open menu 8281 i have changed the software to 716 do i need to do foctory reset to open this menu
    Jan 2009
    doncaster
    Default try this
    have you installed addon 002
    after new firmware 716p
    if using technomate firmware it wont work
    hope it helps alboke
    721p is latest firmware
    use addon 002
    pm if stuck.......
    Stockport UK
    I have the same issue with TM6800HD Supe, I am sure I have seen the file 002 add on somewhere on DK, but when I search, nothing appears.
    If anyone has this add on 002, please could you send to me or even just send the link and I will play myself.
    Thanks in advance.
    AAP
    Here it is mate.
    Stockport UK
    Thanks Manic, I will try it over the next few days.
    AAP
    Hi Manic01, i have installed this addon 2, so what does it do, or how do iuse it?
    cheers
    Hello, i'm trying access the 8281 menu too, i have the 6800 non-super with firmware 6.90p, i have tried installing the 002 file that is on this forum but still can't access it. Any help would be very appreciated.
    swadlincote derbyshire uk
    Quote Originally Posted by Manic01 View Post
    Here it is mate.
    thanks i tryed everything (about 5 diffent patches and restoring factory setting.) trying to get that menu. i use patch 722 didnt realise i needed the addon.
    thanks for that info its been driveing me mad.
    Default Problem after firmware update
    Hi all, I have TM6800 HD Super + and I had firmware 688 (patched) and I used 8281 menu. Not so far ago I have installed latest firmware 716 and patch for it, but I lose 8281 menu. However, menu 8280 is working.
    Any help, please!
    DK Veteran standarren's Avatar
    Jun 2008
    BIRMINGHAM
    Here it is mate.
    himate could you give me the link to 002 add on
  13. #13
    DK Veteran thijs's Avatar
    Eire
    Quote Originally Posted by standarren View Post
    It's not for tm5400 ci usb mate
  14. #14
    Jun 2008
    BIRMINGHAM
    Quote Originally Posted by thijs View Post
    i'm getting closer 9797 on my remote for my 5400ci just have to find the correct software god people are so quite about this subject
  15. #15
    Thers a tutorial on Digitalworldz I think.
