works the original Renault Can Clip with other Software instead of the original Clip Software?
"Rumors" they saying that working with Nissan Consult III Software, but i think they are EXACTLY:
ONLY "Rumors".....
I tried in the past with 1 Nissan Micra, but the Results:
And after that, i discovered, Micra DOES NOT Supported from Nissan Consult III Software.....
So..... Because those days i was not has any other Car for testing, i did not makes any other test.....
You can TRY with Supported Cars by Nissan Consult III with your Sonde and tell us the "Rumors" results.....
Good Luck & Cheers m8!!!!!
PS
IF you plan to "Play" with this, Nissan Consult III Software, exist here on DK Forum.....![]()
China's copy is v92 for the renault can clip interface ,works well but can not update
I have tryed the Nissan Consult 3 Bluetooth Can Interface with Clip Software V97 this works
hi
I have a VI spx interface and it work - clip software up v83 sw for renault cars ,and for nissan cars witj nissan consult III sw.
Hello, I have a renault can clip work with the 104 version, which version of consult work with a can clip?
I have the software consult III V 09:10:01, installed but not recognize the interface, says unregistered .... how to do this?
fifas):
Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
What version you on Ash? Now considering to get Consult3 to run both on it..I do get a few Nissan's through my doors..
BR.
Whatever seems impossible is just not yet important enough.
He talking (needs) about Renault Clip Software Version 104.....
NO anything about Nissan Software!!!
But about Nissan Consult III Software, existing 9.17.01.01.00 Version.....
Use Google and you will discover her.....
Good Luck!![]()
Mate
I've had a chat with Ashraf about this particular tool , and I've told him that I am interested on getting Clip, Lexia and IDS. I am using DEC SS2
DEC Superscan in the ilexa web shop for this makes and considering selling it to go OEM.
Someone above just said Consult3 runs clip sw but not vice versa, so I thought I'd get Consult (instead of Clip) to run both nissan and clip on it, saving on spending towards Clip interface.
Hope I've made it clear now..
Kind regards
YES you can use Nissan Consult III Interface with BOTH Software's (Renault Clip S/W & Nissan Consult III S/W) BUT:
About Renault Brand Cars ONLY from 2003 and ABOVE!!!
(As about the "OPPOSITE" = NO ANY luck!!! I mean Clip Sonde!!!)
So.....
Think - Inspect your needs and choose this that you need.....
Regards!
PS
Renault she naming her "Consult III Interface" = Alliance.....
SAME 100% Interface - DIFFERENT Names!!!![]()
