Results 1 to 9 of 9
    Oct 2008
    Default invalid image using browser and dreamup
    I am trying to flash bonesys image with 14 day epg, when doing it by browser method i get invalid image and also i get invalid image 010 using dreamup...the previous image still works which was nabilo black hole, is there a way to flash erase this ? as i think thats what it may need.
    19:35:39 box type: DM800
    19:36:58 Calculating checksum...
    19:36:59 Uploading file to box...
    19:37:14 box is flashing from its memory...
    19:37:16 Flashing failed (!!! 010 INVALID IMAGE), box will be unusable now!!
    It seems to let me reflash the nabilo image just fine, but bonesys image it wont, i have checked the extention is .nfi, infact i have not altered from its original form.
    EDIT: just downloaded Gemini-4.5-BL72-dreamboxclones.co.cc.nfi and its flashed fine, cant work this out, seems to point to the image file as when i then tried to put bonesys over the top it wont have it but why am i only getting this problem ?
    19:39:41 Calculating checksum...
    19:39:41 Uploading file to box...
    19:39:58 box is flashing from its memory...
    19:42:16 OK, flash-copy succeeded
    Oct 2008
    Now im really pulling my teeth out....i can flash ANY other image except for this one...even bonesys prior gemini image, i have loaded images with bootloader 69,70,72...so why not this...is the flash corrupt itself ? has anyone recently downloaded this and flashed it...can someone put up another upload of it to test ?
    Oct 2008
    BUMP! BUMP! BUMP!
    Oct 2008
    Product Name DM800
    Booloader version Dreambox Second Stage Loader BUILD #72, built 20090303
    Flash Size 64 MB
    Production Date (YYYY/MM/DD) 2009/02/17
    mID 13
    Serial Number 60809
    MAC Address 00:09:34:xxxxxx
    Printed Serial Number 921713000060809
    Oct 2008
    Definateley not my equipment...i have flashed gemini 4 to this with out problem....can someone PLEASE email me thier bonesys 14 day epg image, NOT the one from this site as i can only assume there is something wrong with it as i can flash everything to my box except that one
    Member ZooLio's Avatar
    May 2008
    not much help to youm i know, but i get the same thing with bonesy's image - working on a solution as i type.
    Sep 2008
    Quote Originally Posted by ZooLio View Post
    I think it because your DM has the newer Sim2, Mines has and it wont flash Bonsey image either, and gives the image error 010
    Oct 2008
    But i clearly remeber flashing his first image when he first got his box..unless he is using different equipment now...his input would be greatly appreciated...also, why can i flash EVERY other image except that one...i think the actual image file itself is corrupted although the rar archive is correct and unpacks it ok..that is why it would be helpful to get it emailed from him directly as there is no other source to download from.
    Oct 2008
    Anyone else ?
