whoa hang on there must be at least 3 threads now on the same topic, have a mooch round here, myself sl4k and busaman have been posting, so have a search, dude.
May be admin could do some cutting and butting on here!
I want to In*o off This ecu of Fiat Ducato 2.0 JTD year 2003
0 281 010 346
29f400????
Can i read Flash without desolder??? Galletto ( I have) Peugeto planet system, Lexia or similar..........
I have never desolder an 29f400..........so it will be great, if it is not neccesary......
Very thanks.
Sorry but have read all the post similars, and there is no one with my same ecu.......ones says only in 29f400 others says it is in a eeprom, other says in both...........So I am in doubt, this is why I question about it...Nobody talks about reading flash with galleto to this job.......
But if you consider, I will delete this post.
Thanks.
right not in mood right now but
a) Busaman spend one week buggering with one of these things
he said he put a socket on the board and decided it's in the flash
b) Yes (must remember to say something) the one M-H-M was sussposded to do was done by some other company not from Meat-Headshire and they
said it WAS in the flash. Heard in the grapevine that there is a permant fault code of U1600 and they ended up placing a bit of tape in the led of the MIL
(naughy naughty)
After reading several post about it, I am going to read 24f900 via OBD with galletto. Can I?
I mean if I can read directly with OBD . If I am not wrong my ecu it is a EDC15C7. When I read dump I will post it.
Some ecus cannot been read by this way, can I read and write 29f400 for this purpose???
I do this because at the moment the only programmer I have X-prog M is come back to factory, I had several problems with it, so I have no more option at the moment.
Thank you.
This is dump of 29f400 I dont Know if it is ok, I have read several times, always same result so supose it is ok, I have read With galletto interface without problems....Anyone help me to in*o off???
Once have write again the new dump in ecu.must I cut any wire or it is not neccesary???
I use galletto because I have not programmer at he moment, both are in factory one for update and other because is a ****ing clone.....
I will try and say you, supose there not any problem, in thery galletto could read and write this 29f400 of this ecu without problem, but you Know.
Should I cut any wire, or sympli disconnect forever any inmo module???
very thanks
will this work on a 2.3 JTD
Hi Adam
i know tell me about it
im pretty sure it will be like the pug i did so it will need a vigin flash file and a modified eprom then have to be configured to the car.
and yes it would be nice (polite) for people to post the outcome good or bad but i guess some people just want the answer and never come back.
7.31sec@203.3mph
