Results 1 to 2 of 2
    Aug 2016
    Bulgaria
    Default Renault Espace 4 2004 dashboard turn off when engine is started
    I repaired the power supply part of the dash.
    It is working fine now on the bench. Supply 11.6-17V DC no problems - always on.
    The guys at the garage connected the dash - working fine.
    The problem is that when they start the engine and dashboard is slowly fading out till completely off.
    Also all pins signals compared with a working one dash - all signals are the same.
    Does anyone expierenced same issue?
    Can someone check the dump for errors?
    Thank you
    1. Renault Espace 4 2004, diesel
    2. EEPROM: Microchip 93c56 Dashboard: Ind: J v5.2 OEM: 8200 288 814 H
    3. Mielage at the moment 275 090km
    Aug 2016
    Bulgaria
    Resoldering everything under the big display solved the issue.
    Cheers
  3. The Following 2 Users Say Thank You to kalki85 For This Useful Post:
    Drdiag (27th May, 2023), eliet2000 (27th May, 2023)
