Results 1 to 12 of 12
    Oct 2008
    watford
    Default Technomate 5400CI+super
    Have installed motorised system with a lot of help from previous posts on this site. To be honest still do not fully understand how the 5400 box operates as instructions are basic. I have patched receiver and seem to be picking up most channels from the various satellites but not all. My question is should i muck about with transponders stored and if yes ! how?
    thanx
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    No. Your firmware probably contains transponders which are no longer in use or in a beam which isnt for the uk
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
    Aug 2008
    var/tuxbox/plugins
    No. Your firmware probably contains transponders which are no longer in use or in a beam which isnt for the uk. Can you give me a transponder and sat and i wil try to help.
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    V.I.P. Member alunfennell's Avatar
    Oct 2008
    Try the new patch issued yesterday 5400CI+ 5600CI 150p
    Oct 2008
    OOH sorry its the Super model just make sure you select the super patch....
    Regards:
    Alun
    Oct 2008
    watford
    Had a bit more time to look at receiver and now realise that when a satellite is scanned the receiver uses all transponders to get the channels. So when I go to say hotbird and view the channels each channel uses its relative transponder.I think! If you do a software update does this also add channels as maybe this explains why I have extra channels that are FTA but can t view. Thanks for update will give it a go! Thanx for help
    Sep 2008
    did your 5400ci come preloaded with the channels from technomate?< only as good as the date they were created
    if so load a upto date channel list on your stb
    usb-data transfare upload channel list
    or back up your channel list delete all your channels on stb and do a blind scan of all sats you revieve in one go
    Oct 2008
    watford
    Thanks Ireland-batt
    what u say makes sense
    I think only have default channels
    I have stb back up so I will try blind search
    many than
    Aug 2008
    var/tuxbox/plugins
    Why not use auto navigation and then use blind scan on 42e turksat and 1 west. These two satellites hav had major transponder changes so just blind scan them two and auto navigate the others. This will be quicker and more efficient.
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Oct 2008
    watford
    Did as you said except on turksat as my arc finishes at 30e and do appear to have more channels yet to check all sats
    many thanx for help
    Aug 2008
    var/tuxbox/plugins
    Does your motor not go further?
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Oct 2008
    watford
    Yes it does but then next doors extended house blocks signal
    bit of pain
