Results 1 to 15 of 15
    Apr 2015
    Sweden
    Default Program keys Golf 7
    Hello , a friend has Golf 7 blade key MQB year 2019 and wants spare key. A locksmit friend told me to stay away from Golf 7 from 2015 and up, he used VVDI2 to add a aftermarket key. And ended up with no working key. He had 100Amps power supply on. This car had to be fixed by odis. What to do? Stay away? Anyone
    Mar 2018
    UK
    Usually after 2015 you can face digital dash or JC dash both arent possible by OBD
    if is VDO dash no problem easy job by OBD
  3. The Following 3 Users Say Thank You to Manta1600 For This Useful Post:
    baddaren (31st May, 2023), fuzz1 (5th June, 2023), key4man (31st May, 2023)
    p1et's Avatar
    Oct 2013
    Mate, consider if this locksmith friend is really your friend
  5. The Following User Says Thank You to p1et For This Useful Post:
  6. #4
    Apr 2015
    Sweden
    Hello Manta, thank you, May I ask what tool you are using? VVDI2? Regards J
    Mar 2018
    UK
    Quote Originally Posted by baddaren View Post
    It doesn't mater what tool you use if is JC dash you will have message that this dash is not suported by OBD
    I use VVDI2 and Autel
  8. The Following User Says Thank You to Manta1600 For This Useful Post:
  9. #6
    Apr 2015
    Sweden
    Hello again, does it work with aftermarket keys, xhorse keys,MQB style or must it be orginal VW Keys (OEM)? J
  10. #7
    Jul 2019
    Melbourne, Australia
    All the solutions for MQB spare key making utilise aftermarket keys fine. Xhorse offer to use their remotes to re-generate one of the already learned key IDs so ODIS won't spit an error for unauthorised key IDs if it is connected. If you're going to the trouble of buying a genuine VW key you may as well just learn it with ODIS and a GeKo login rather than stuffing around reading dashboards and sync data from working keys.
  11. The Following User Says Thank You to Spiritech For This Useful Post:
    baddaren (3rd June, 2023)
  12. #8
    Apr 2015
    Sweden
    Hello dear friends, As I understand I have customer with Golf 7 year 2019, no prox. Add key (OEM 5G0 959 752 DD) . I can use Xhorse MQB universal key XSMQB1EN. If using VVDI2 it will tell what dash it is, only VDO dash is possible. Or is it better to use OEM(orginal) key, not precoded? Did I understand it right? Regards J
  13. #9
    Apr 2022
    Germany
    Most of obd2 tools which support Golf 7, after you connect it, will show you what kind of dash you have (jc, vdo)…
    vvdi2 has also diagnostic software…
    Member Spiritech has already explained about original and Xhorse key..
    Original or aftermarket keys can be programmed only once and most Xhorse keys can be reused…
  14. The Following User Says Thank You to wuza For This Useful Post:
    baddaren (5th June, 2023)
  15. #10
    Jul 2019
    If you've not done these before and you're concerned about breaking things just buy a dealer key and use ODIS with geko.
    MQB spares are not hard until the dashboards start refusing the bootloader to read the immo data with working key or when dashboard is VC/JCI. Your 2019 may have a dashboard that won't read out and to do an aftermarket key you will be pulling the dashboard, lifting FVDD and reading the MCU in the dash for immo data, or paying for immo data(not really economically viable for spares). That said, plugging in to check the dashboard vendor isn't going to hurt the car in any way, the tool will tell you before it tries anything.
  16. The Following 2 Users Say Thank You to Spiritech For This Useful Post:
    baddaren (5th June, 2023), fuzz1 (5th June, 2023)
  17. #11
    Apr 2015
    Sweden
    Hello Spiritech, if use ODIS with geko, dealer key must be precoded from dealer? I can buy OEM keys not precoded, thats why asking. Regads J
  18. #12
    Jul 2019
    Yes, to use ODIS must be a dealer key with pre-coding.
  19. The Following User Says Thank You to Spiritech For This Useful Post:
  20. #13
    Apr 2015
    Sweden
    Thank you Spiritech, May I ask, if get precoded OEM dealer and program with odis, I can make all dash? Johnsson Control and virtuell and VDO ? Regards J
  21. #14
    Jul 2019
    Yes, dealer key + ODIS is full support. I've done VC, JCI and up to MY21 vehicles with a dealer key and ODIS. It works for AKL too, just need to wait for the key.
  22. The Following User Says Thank You to Spiritech For This Useful Post:
    baddaren (16th June, 2023)
  23. #15
    Jan 2017
    Netherlands
    Even if VDO it's not all peaches for 2019 Golf. Had one last week and could not do it with VVDI2 - it kept telling 'wrong type selected' , whatever I did , even when it detected it as VDO also. Ended up ordering dealer key and programming it with Odis. Not a real problem but generates way less profit. Autel ofourse already gave up when it smelled the letters MQB but normally VVDI2 is getting the job done quite easy (2019 models of certain cars done before , as long as it is MQB48 and ofcourse no JC or VC)
  24. The Following User Says Thank You to Matronix For This Useful Post:
