Hello everyone, I am new here. I have seen people posting about using VCDS cable to use VAG K+CAN commander. I have been trying since this morning but now luck.
Is this because I'm using Windows 10? does this VAG K+CAN V3.6 commander software only work on windows xp?
I'm getting following error when I run the application VAG K+CAN V3.6.
First I get "open port failted", if press okay I get "Cannot Find Device" and the programme shut it self.
is this because of the VSDC cable or something else
I also could see "SCOMM SET' button in the application. my VCP is set to COM 2
If you have any suggestion, that would be really helpful.
Thank you in advance.
