Hi guy's
Hope you can help, i am desperatly in search of a dash dump for reprogramming a motometer highline dash (2003model). It keeps throwing fault code 01794 and 00474 after just disconnectin the battery.
after a 10 minute drive tha airbag light comes on. Deu to corrupt software in the dash. It has to be programmed with dataversion D18 or change the cluster with the 8H0 920 931 TX
In the audi world is this a known problem of that series of dash, for me it's the first time.
Any help on this is appreciated
8H0 is RB4 you cannt rewrite any dump. Rewrite VIN to your original dump. If you write different dump to dash you will get DEF message on display
Ok thanks, but how should i rewrite the VIN?
This one is realy new to me , i do not know how to begin.
this is bosh cripto , in this case you must have same vin in airbag tcu and ecu . If you have diferrent vin on airbag and instrument that fault is present
1.First of all, for your information, check with VAG-COM channel 81 (measuring blocks) in ECU (01), dash (17), airbag (15) and central electric (09). In all units should be the same VIN. In both cases, when it's equal or not, you can try to readapt your dash to the car again. Get login (from dash or ECU) of your vehicle and use following procedure:
Connect to dash (17)
[Login - 11]
Enter your vehicle PIN.
[Do it!]
[Adaptation - 10]
Enter 050 in "Channel Number".
[Read]
You'll see "32000"
[OK]
VAG-COM will validate the data you have entered and return you to the Login screen, where the Login Code will show as "XXXXX".
[Test]
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Switch OFF the ignition and let the car sit for ~1 minute, then switch ON the ignition again.
Verify that the NEW (USED) instrument cluster now shows the VIN/im*o-ID of the vehicle now.
2. If your problem will appear again, you may try to find software D18, as you wrote (unfortunately i don't have one as you asked me via PM), upload it to eeprom (cable or programmer) and readapt dash:
[Login - 11]
Enter PIN of new dump.
[Do it!]
[Adaptation - 10]
[Read]
You'll see "32000"
[OK]
[Test]
[Save]
[Done, Go Back]
Proceed with key matching.
[Login - 11]
[Do it!]
[Adaptation - 10]
Enter 21 in "Channel Number".
[Read]
The "Stored Value" is the number of keys currently matched.
Enter a "new value" corresponding to the total number of keys to be matched, including any existing keys.
The old keys are automatically beeing cleared.
[Save]
[Done, Go Back]
Repeat the following steps until all keys have been matched:
Switch ignition off and remove key.
Insert next key to ignition and switch ignition on again.
The warning light for the im*obilizer will light up for ~2 seconds, then go out Switch ignition off and remove key.
Note: The above steps after saving the adaptation, should not exceed 60 seconds!
3. If you will be unable to get version D18 you can buy new or used dash with number 8H0920931TX and readapt it like in second case.
werner5395 (7th December, 2020)
Thank you verry much for the detailed help.
I will try it first thing tommorow.
Thx again m8
HI ! a dump for my dash PLS ?...
8D0 919 033 D eeprom 93c56...6 clocks dash
it is an A4/1995/ADR
forgot to mention : is VDO or UK-NSI ? i put both ways...maybe one of them will help you.
rob h (22nd April, 2016)
thank you veryyyyy much
