Results 1 to 3 of 3
    Mar 2021
    Default need immodata for med17 ecu
    Hi friends,
    Can any one calculate the immo data for VW ecu Med17.5.21
    in order to adapt dash.
    kuebk's Avatar
    Feb 2016
    Not sure if this will work out as cluster might be using 12 byte CS.
    CS: 8F1858438098A88655107A368F83CDB2
    MAC ECU: 5494
    MAC CLUSTER: C6E2
    POWER CLASS: 0F
  3. The Following User Says Thank You to kuebk For This Useful Post:
    masterkey25 (5th June, 2023)
    Mar 2021
    Default dash immo data
    Quote Originally Posted by kuebk View Post
    MAC ECU: 5494
    MAC CLUSTER: C6E2
    POWER CLASS: 0F
    Can you prepare the immo data if I send you the 2 dash files?
    the original is Magneti Marelli and the one I want to adapt is VDO
