any help please i need a code to resync my key fobs on renault scenic 1999 as they dont work the central locking anymore i have looked inside the keys and have found s108627bno on the board and 99273
You should look for a 5 digit number in the plastic housing. This always starts with an S.
In case your remote is not IR but RF, turn ignition on and off, hold remote button until it stops flashing (about 10 seconds), than release and push button again 3 times.
hello and thanks for your advice my key fob is an RF i have 2 keys i have looked inside of them and the number i find on both is s108627bno so if i have to enter the 5 digit code lets say 10862 how can i enter the 0? and do i need to? any help would be great thanks again
if your key is rf then the code doesnt work its only for infra red keys have you tried key ignition as described above?
ok thanks will try the key in ignition tomorrow and will reply if it works thanks again
tried what you said and it still refuses to work gona have to get someone to take a look at it but was still worth a try thankyou
