Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 118
    Jakarta, Indonesia
    Default how to synchronize DME and EWS
    hello, all
    I had a problem in the shop, my customers come with the car bmw E46 M34, year 2000. With missing ecu conditions, and I get the ecu used. and how to sync ECU with EWS.
    I have read the flash ecu, and ews.
    regard
    post your exact engine ecu info .do you have gt1 ???
    Is this an EWS 2 or an EWS 3?
    Senior Member drivergabriel's Avatar
    BUCURESTI
    try with inpa.
    Toronto, Canada
    Default Synchronize Will Not Work
    Password in the DME must match with tables in EWS3
    When DME is virgin a write once pasword is burnt into the AM29F200BB.
    I have the same vehicle and have not yet solved the problem.
    I have GT1 and Inpa, SSS will reprogram the VIN but not the password.
    I am talking with a supplier that says he has a solution with this tool http://www.cardiagnostictools.com/keyrlight.shtml , but removal of the chip is required.
    If anyone else has solution please share or if someone has a virgin dump of AM29F200BB .... hook me up thanx
    Jakarta, Indonesia
    Quote Originally Posted by PAVLOS2 View Post
    hi,
    this engine type M43, and i have GT1.
    regard
    Jakarta, Indonesia
    Quote Originally Posted by oldford View Post
    this ews 3.
    Toronto, Canada
    BMW E39 E36 E46 E38 X5 X3 Z4 Z3 DME PROGRAMMING on eBay.ca (item 180422799822 end time 20-Mar-10 11:31:01 EDT)
    Offers a solution to the problem and cost is about 200.00us plus shipping. If I can't figure it out I will have to send him DME and EWS with a key and he will reset everything .... plug and play after you pay.
    obdmaster's Avatar
    Never never land
    Thumbs up Try this
    Just an idea.
    Read ISN of DME, with inpa.
    Then with inpa again you can write ISN to EWS.
    This is what i did when i replaced EWS unit, for a 1998 E39 with ews 3. Hope it works for you m8.
    Jakarta, Indonesia
    I try to edit the file with ews ews editor, but it did not work
    and create a file ews virgin, still can not sync with DME ews
  11. The Following User Says Thank You to bali motor For This Useful Post:
    john chan (16th June, 2020)
  12. #11
    i use pa soft on most models with ews3 it reads the password then i remove ews change password resync with pa soft job done
  13. #12
    Jakarta, Indonesia
    Quote Originally Posted by obdmaster View Post
    Just an idea.
    thank you i will try your idea..
  14. #13
    Jakarta, Indonesia
    I HAVE EDIT THIS FILE EWS
    original file to make factory file from ews editor..
    but can not scyn too,,
    how to read password in ecu?
  15. #14
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by bali motor View Post
    Using inpa go into DME, then coding. Then read ISN m8.
  16. #15
    BUCURESTI
    ........i resolve this kind of proble m with inpa....
  17. The Following User Says Thank You to drivergabriel For This Useful Post:
    rokashius (21st April, 2017)
