hello bali motor.... it`s sincronyzed ews3 and the dme ?
because it starts but stops. No errors
here the dump
here the dump
i try....and i report the conclusion.
inpa non comunicate with the ecu...
need another tools..![]()
this is the software...should work
autoTkey (10th July, 2020), brend (1st February, 2018), darkshiningg (11th September, 2017), electronicdeivi (30th October, 2021), eliah (31st August, 2017), INFINITY13 (12th January, 2017), jaelgti (26th November, 2013), jodies auto (31st October, 2018), key4man (24th December, 2022), okm (24th July, 2018), r1yamaha (5th May, 2019), sapopt (14th February, 2019), t1tan1 (30th August, 2015), tarmacblack (29th January, 2019), vavrich (11th January, 2023), woodoo (21st June, 2013)
sorry...it`s rover 75 1.8 benzin ecu with ews3 .the ecu is some motorola....i don`t find the label....but the pcb is printed with the motorola with flash 29f200.
the bin are atached in previosly post
try this file and write to ews .
cj
O2 senser connectors melted. Since chk engine light on. Have used ecu and tring to sync them? Used ecu and have the ews from the same car. Trying to sync with p a soft 1.3.6.![]()
if u post the dump of ecu then i can virginise ece then u ncan sync
hi can somebody please virginise this file from a used EWS 4 .
the original EWS is damaged and i cant read 9s12d64
its from 2009 bmw X3
this file i read it with original ROSFOR
thanks in advance
u will need read ecu ,or isn if u can from ecu and then pair it with ews and sync also the ews u read should be in .bin not .rs1 format which u have read
regards
Hello
I have problem to synchronise DME1 with wes3, fault in ECU is EWS-DME interface. Can someone check the password in dme for me please? (looks like someone before me removed the flash - i do not know if its corrupted or no).
use this id is clear sync and all should be fine
Not working - can not synchronise.
