Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 60
  1. #31
    Sep 2016
    i got working one how to read it ???
  2. #32
    Newbie Pfennig's Avatar
    Sep 2023
    firstly, you need skills in working with a programmer, for example ST-Link V2. all details about how it works are available in Internet:
    https://labs.portcullis.co.uk/blog/g...ng-st-link-v2/
    unfortunately, I don’t know how to do this, although I would really like to learn.
  3. #33
    Smart66's Avatar
    Dec 2020
    Anyonee who had solved it? After a few months there is no solutions still I've already bought a new STM32F405 Chipset but I haven't got proper dumps for flashing
  4. #34
    Sep 2023
    to take a dump from firmware you need ST-Link V2 and software/utility.
    SWD PINS: 3,3V, SWDIO, SWDCLK und GND (4 PINS on the top edge and the last one on the right is not soldered)
  5. The Following User Says Thank You to Pfennig For This Useful Post:
    dmerkovic (24th July, 2024)
  6. #35
    Smart66's Avatar
    Dec 2020
    ST-Link V2 Programmer isn't problem because I can find it out easily. What dump should I flash? That is all what I need
  7. #36
    Sep 2016
    i got a working cables many working and i got the st link v2 i will connect can some one tell me the steps and the program name exactly i got one called stm cub programing is it the one ??
  8. #37
    Sep 2016
  9. #38
    Smart66's Avatar
    Dec 2020
    Which chip uses your VCDS cable? That's STM32F405, isn't it?
  10. #39
    Sep 2016
    yes stm504 i got a lot of it
  11. #40
    Sep 2023
    if you can’t just take a dump from the firmware, it means the chip is protected from reading and writing - nothing will work without special knowledge and experience. you'll just have to buy a new cable. sry (((
  12. #41
    Smart66's Avatar
    Dec 2020
    Chipset might be revived but it depends which level of RDP is activated. I'm convinced that is possible so it won't be easy task
  13. The Following User Says Thank You to Smart66 For This Useful Post:
    heshamzn (2nd October, 2023)
  14. #42
    Sep 2023
    the parasitic firmware, represented by the latest version of VIIPlusLoader, deliberately programmed the wrong VID&PID, now the cable in Windows is detected incorrectly, and therefore cannot be recognized... because of this, it also cannot be recognized by the flasher.
  15. The Following User Says Thank You to Pfennig For This Useful Post:
    DreamDancer (12th October, 2023)
  16. #43
    Nov 2015
    romania
  17. #44
    Smart66's Avatar
    Dec 2020
    That's same VCDS chipset as mine. Did you brick this VCDS cable?
  18. #45
    Sep 2023
    this is full version on the 405th chip. updated online, cost approximately $80, plus/minus.
    https://www.aliexpress.com/item/1005...d=fjmdXqZbLEmy
  19. The Following User Says Thank You to Pfennig For This Useful Post:
    amstel7 (10th November, 2023)
