    Jun 2020
    Default MB Sprinter DTC delete
    I need someone to do DTC delete from Delphi CRD3P.CO ecu.
    Oct 2015
    test and report
    alonedark's Avatar
    Feb 2017
    you want to remove this dtcs only
    Jun 2020
    For the test yes, why do you ask?
    Jun 2020
    Thank you, I will test it and reply
    Jun 2020
    @REMZI1984
    Thank you for your help, we were able to use it in the tests and found the problem with the vehicle.
