Results 1 to 3 of 3
    Mar 2017
    GB
    Default problem with el. power steering punto 188
    Hi, I have problem with punto elektrik power steering .
    Once a week PS stop and error code is P1015 ECU Fault.
    Replace ecu... In live all its ok...wire its ok....
    Fiat punto 2000y 1.9jtd
    Apr 2022
    Germany
    Problem with electric steering wheel on Fiat Punto can be following:
    - relays,
    - control unit from steering wheel
    - steering wheel sensor (ring under steering wheel).
    In most cases the errors showing right problems, but sometimes not.
    I. E. Fault with steering wheel control module never showed directly.
    So if you have spare parts you can test it. At least motor and control module are easy to change.
    p. s. I did had once problem and after changing all those 3 things/ parts the problem was still there.
    New parts can be also bad, but not all 3 new parts at the same time.
    At the end turn up that voltage with engine running was about 14,7V…
    I spent about 5-6 hours just to find problem…
  3. The Following User Says Thank You to wuza For This Useful Post:
    plam1972 (12th June, 2023)
    Mar 2017
    GB
    I thinк too for voltage..... motor and ecu is replace ... sensor its ok in live...
