OPCOM 090821 VERSION
Results 1 to 6 of 6
    272
    Downloads
    64
    Uploads
    Default OPCOM 090821 VERSION
    TRYED TO PROGRAM A SECOND HAND KEY FOB ON A CORSA C 53 PLATE USING OPCOM. PUT SECURITY CODE OF THE CAR IN AND THEN PRESSED ON PROGRAM KEYFOB, IT SAID PRESS 1 BUTTON ON KEYFOB, BUT WHEN I DID THIS NOTHING HAPPENED, TRYED SEVERAL WAYS BUT JUST WOULD NOT WORK. IS IT SOMETHING IM DOING WRONG. I NOW THE FOB WAS WORKING AS I TOOK IT TO A GARAGE AND THEY USED TECH 2 TO PROGRAM, IT TOOK JUST A COUPLE OF MINUTES AND WORKED FINE. ANY HELP WOULD BE SUPERB. THANKS
    OPCOM VERSION I USE IS 090821.
    obdmaster's Avatar
    Never never land
    335
    Downloads
    Uploads
    Lightbulb hhhhhmmmmm!!!!!!!!!!!!!!!!!!
    Quote Originally Posted by radiosolutions View Post
    I had problems with 090821d, when trying to program a psg16 diesel pump on vectra c, i hit the "do it button" and waited and waited and waited. Luckily i had both 090714en and 090821d installed on same laptop and went back to 090714en where it worked perfectly. Seems as this version of 090821, has programming flaws to me m8.
    272
    Downloads
    64
    Uploads
    thanks for that reply .could you upload me a version of a working 1 if you have it please.
    obdmaster's Avatar
    Never never land
    335
    Downloads
    Uploads
    try these m8
    http://www.digital-kaos.co.uk/forums...tivated-54787/
    272
    Downloads
    64
    Uploads
    the link appears to be broken as when i click on nothing happens m8
    Member drdre20013's Avatar
    Jul 2009
    Downloads
    27
    Uploads
