Results 1 to 8 of 8
    Oct 2008
    Default TM 9100 Super Hanging
    I tried to flash my technomate with lastest ur image now it just hangs on boot wiith ur logo and display just going around and around
    tried re-flash with serial cable doesn t seem to connect can connect to dreambox but
    i was flashing over the network but network port is dead also
    bo just powers straight on when flick the power
    any pointers would be great
    Jun 2009
    not sure if this will help as it may be what you are already trying this is thanks to "digidude"
    Oct 2008
    ill try it and let you know thanks
    Oct 2008
    cheers thats the ticket
    Sep 2011
    I got similar problem on my TM-9100.The box just hang on the UR Logo.If I installed the Technomate Image then it would work OK.I didn't see any suggestion from Dick B above.Thanks!
    Jun 2009
    Quote Originally Posted by cl163 View Post
    yeah thats an old post but this is what I sent him
    Sep 2011
    Thank you Dick for uploading the Link again.I had no problem with Reflashing by Serial.I have tried a few UR images,and the box hangs on reboot.Is there anyway I can force a Reboot after reflashing? The box reflashed OK with Technomate image,so assumably there is nothing wrong with the Flash IC,isn't it? Is there a bug on the UR images?
    Sep 2011
    I have found a solution to the Hanging on Reboot after Reflashing.This results from a corrupted Uboot image.The problem can be resolved by Reflashing the original TM-9100_Serial_005 Uboot image into the box using the Serial Null Modem method and the box would boot again.Hope this information would be of any help to someone
