Results 1 to 4 of 4
    Jan 2015
    Default Polo 2011 dashboard imodata
    Istrument cluster 6R0 920 861 F there is a processor inside UPD70F3425.I tried to read it vvdi prog reads ID but when reading flash it throws an error. has anyone read this board.I have a dashboard from a donor, I need to clone an imodata
    THANKS
    If I helped you in any way please click the Thanks+Rep button
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by tirnanic malisa View Post
    THANKS
    You can't just copy and paste.
    Put dash in service mode.
    the lesser you use your brain,
    the louder you use your mouth.
  3. The Following 2 Users Say Thank You to Ninjor s For This Useful Post:
    tirnanic malisa (15th June, 2023), urcarpc (19th June, 2023)
    Jan 2015
    i need a pin out to work on the fvdi table
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    ...................dash obd2 pinout
  6. The Following 2 Users Say Thank You to Ninjor s For This Useful Post:
