Results 1 to 15 of 27
    Default bmw x5 key programming
    i have one bmw x5 with one original key,i need two more keys,how can i program the 2 keys on-board?
    Hello
    You can do it for example with the AK400 (for BMW, the device is OK) programmed into the CAS.
    Marco
    what year is bmw and what tools do you have ie programmer key machine
    am having t300 key programmer,the vehicle should be 2003
    gepakg's Avatar
    Serbia
    impossible with t300 or ad100
    read EWS3 and post dump,key can be created in pcf7935
    regards Gepa
    Quote Originally Posted by ezenigbo View Post
    can somone give me wiring diagram for reading the motorola mcu ? but as am havig the key logic for the original key,is there no way to write thesame logic to a chip to start the car?
    gepakg's Avatar
    Serbia
    be care with reading this MCU,some masksets are secured and when you try reading possible to erase eprom and lost sychro between ews & ecu...
    from dump i will make for you key logic for active keys
    regards Gepa
    gepakg's Avatar
    Serbia
    by me ETL hc11 programmer is the safest way for reading secured MCU`s...
    Quote Originally Posted by gepakg View Post
    regards Gepa
    here is the dump
    cjawahir's Avatar
    T&T
    looks good , you can make key for position 4,5,6.7.8.9.
    vin # WBAFB31020LG94905
    prod date 29 09 00
    what programmer did you use ?
    cj
    i used carprog,please enlighten me more on how to make the key
    gepakg's Avatar
    Serbia
    your VIN is WBAFB31020LG94905? and mileage 245384 km?
    regards Gepa
    here is the dump
  13. #13
    gepakg's Avatar
    Serbia
    do you have zed-qx or kmrw ?
    logic for first key: 5500D758F98CAFA959BF
    also you have now 4 activated keys
    regards Gepa
  14. #14
    cjawahir's Avatar
    T&T
    well you did the the most difficult part read the ews 3 ,
    you just need transponder programmer like Gepa said, also you can check this Gambit programmer CAR KEY MASTER II | obdchina
    cj
  15. #15
    please give me more 2 logic,i have zed qx ,what type of transponder should i write it?
