Results 1 to 4 of 4
    kaToo's Avatar
    Default Suzuki vitara 2017 AkL impossible add key
    I have a suzuki vitara with AKL situation
    I try add xhorse key with lonsdor and was impossible . When say put key at start button key light flash and error on lonsdor. After many try costumer found the old key and now it seenms it is deleted. Now when try to add ori key back it fails same like xhorse key. Does anyone know of this cars can have any wait time or what could be problem.
    P.S i short wire in fuse to make ign on same like it says in manual.
    258's Avatar
    Germany
    i have same Car with same Problem, have solved this Porblem with key learning?
    Jun 2013
    Worked with a S-Cross a while back.
    Prox key.
    Spare key.
    Tried first, with one of the Prox China keys I had in stock.
    Thought they might supersede, each other.
    But not possible, to Add key failed.
    Then tested several Horse-prox keys.
    Did not work either.
    Then told the seller (second hand, car dealer).
    Probably need a key, which is guaranteed to fit the car.
    Seller got the key, a couple of days later at the local Suzuki dealer.
    I meet up, one more time.
    And add the key, with no problem.
    I think I used the IM-tool, at that point.
  4. The Following User Says Thank You to Weasel3 For This Useful Post:
    wuza (14th September, 2023)
    Mar 2018
    japan
    P.S i short wire in fuse to make ign on same like it says in manual.[/QUOTE]
    Hello kaToo
    Please tell me the wiring if you don't mind.
