Results 1 to 15 of 17
    Oct 2008
    Default Scart socket hum
    I was using my openmedia box via the wire that came with it but today deceided to wire it up using a scart lead. However when I switched to the relevant AV channel on the television I could not hear anything apart from a strong electrical hum.
    I switched back to the wires with the box and plugged them into a scart socket and it worked fine. I have tried a different scart lead but it made no difference.
    Is this a known problem ? or is there some setting I need to change ?
    Besides this problem it is a great little box.
    Thanks in advance
    DK Veteran portbhoy's Avatar
    Sep 2008
    It is a great wee box but it is also very cheaply made I know one that smoke started to pour out of it I would return it as faulty theres obviously something not right in there!
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Could be one of the audio input pins which are damaged.
    Get a audio video cable and on one end put a scart adaptor. Put the scart in the receiver and the wire end in the tv. Then do it vice versa. Check the if the combination equates to a hum or not and take a note. This will narrow the prob down.
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
    DK Veteran psats's Avatar
    Sep 2008
    try useing a NONE fully wired scart {one way}
    plus you can get that hum if you not got the suppressor on the incomeing feed
    Aug 2008
    var/tuxbox/plugins
    What one of them?
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Sep 2008
    mee maw mee maw mee maw, thats a sound Mept's familiar with
    Aug 2008
    var/tuxbox/plugins
    Quote Originally Posted by portbhoy View Post
    I dont know about you but our fire vans dont sound like that.
    Do these catch fire that easily? Its better to just set 10 tenners alight
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Sep 2008
    Do they not, it used to be ne naw ne naw, them wooo, wooo, wooo, wooo but now it's me maw, me maw. It's the only one I've heard of thats went on fire when Mept opened it she said it was quite messy in there with loads of the red stuff they sually cover the screw heads in
    Aug 2008
    var/tuxbox/plugins
    Hopefully the scart isnt damaged. Scart is meant to be higher quality.
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Oct 2008
    Thanks for the suggestions guys and to max who offered to replace the box.
    I had another play with it using another television and used a cheap scart lead with flat ribbon and the problem appears to have vanished. I think the fancy scart leads I was using may be a bit connector heavy and may not have been making proper contact with the female scarts on the television or openmedia box. Plugged it all back into the original television and no audible hum yet.
    I guess no more fancy heavy scart leads with gold plated connectors from now on.
    Sep 2008
    Glad your sorted mate, just for the record my box works fine and I'm very happy with it for the money it's a solid buy
    Sep 2008
    o.o im on my 2nd box and i got the hum too o.o
  13. #13
    Sep 2008
    Quote Originally Posted by bigman2 View Post
    can you tell me ware you got this ie scart lead ribon as iv side im on the 2nd box and got the humm too allso im geting gosting from the menu too =( i can get hold of max ther phone is nother anserd my be fult on the line
  14. #14
    Apr 2008
    im not always able to answer the phone but email is best way to get hold of me
  15. #15
    Oct 2008
    Try ebay and search for flat ribbon scart.
