Results 1 to 12 of 12
    Question Report firs Vagcom Test: I need Help !
    Hi friend, yesterday I give a first test to my car (audi a4 2.0tdi PDE 140cv) with vagcom. There are some fault code, but I don't know the meaning of these error code.
    There are the errors:
    Address 03: ABS Brakes Labels: 8E0-910-517.lbl
    Part No SW: 8E0 910 517 B HW: 8E0 614 517 AT
    Component: ESP8 front H04 0180
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0004401
    Shop #: WSC 06325 000 00000
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 13
    Time Indication: 0
    Freeze Frame:
    Hex Value: 0x0000
    Hex Value: 0x4022
    Hex Value: 0x00FF
    Hex Value: 0xFFA1
    Hex Value: 0x00FF
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AM
    Component: A4 Klimaautomat 2731
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    Address 15: Airbags Labels: 8E0-959-655-94.lbl
    Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
    Component: Airbag 9.41 H10 3230
    Revision: 91H10323 Serial number: 0036M001GV4/
    Coding: 0033622
    1 Fault Found:
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 99
    Time Indication: 0
    Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
    Part No SW: 8E0 920 900 R HW: 8E0 920 900 R
    Component: KOMBI+WFS 4 H12 0040
    Revision: 0040 Serial number: 00000000000000
    Coding: 0006541
    Shop #: WSC 23230 126 00413
    1 Fault Found:
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
    Component: RNS-E HIGH EU H51 0650
    Revision: 07S Serial number: AUZBZ7D0025207
    Coding: 0309217
    Shop #: WSC 06348 116 57032
    4 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 179
    Time Indication: 0
    Date: 2010.03.18
    Time: 16:11:12
    Freeze Frame:
    Voltage: 10.40 V
    Mileage: 655350 km
    Count: 1803
    Clock: 16:10
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01111011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    01303 - Telephone Transceiver (R36)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 54
    Time Indication: 0
    Date: 2009.02.04
    Time: 10:43:54
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BG
    Component: Komfortger?t T85 2431
    Coding: 07024
    Shop #: WSC 06325
    Part No: 8E1959801B
    Component: T?rsteuer.FS BRM 0205
    Part No: 8E1959802B
    Component: T?rsteuer.BF BRM 0205
    1 Fault Found:
    00956 - Key 2
    35-10 - - - Intermittent
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0309217
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 179
    Time Indication: 0
    Date: 2010.03.18
    Time: 16:11:12
    Freeze Frame:
    Voltage: 10.40 V
    Mileage: 655350 km
    Count: 1803
    Clock: 16:10
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 35
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 54
    Time Indication: 0
    Date: 2009.02.04
    Time: 10:43:54
    Can someone help me with these error code ?
    How can I solve ?
    Best Regards
    Ashraf6119's Avatar
    UK
    Have you tried to clear them and see which once come back
    Ash
    Try here for more help.Insert your fault code and read the explanation Category:Fault Codes - Ross-Tech Wiki
    Quote Originally Posted by Ashraf6119 View Post
    Ash
    No Ash I don't clear them.
    How can I clear these errors ?
    Quote Originally Posted by viorels1
    Wow !!!!
    I reset all DTC error and re-give an auto scan.
    This is the report:
    Address 01: Engine Labels: 03G-906-016-BLB.lbl
    Part No SW: 03G 906 016 GN HW: 028 101 211 3
    Component: R4 2,0L EDC 0000SG 7004
    Revision: 12345678 Serial number:
    Coding: 0000072
    Shop #: WSC 00191 264 15243
    No fault code found.
    Readiness: 0 0 1 1 1
    Coding: 0004401
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    35-00 - -
    Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
    Part No: 8E0 907 279 L
    Component: int. Lastmodul ECE 0304
    Coding: 10021
    Shop #: WSC 06325
    Coding: 0033622
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenks?ulenmodul 0601
    Coding: 02012
    Shop #: WSC 06325
    Coding: 0006541
    Coding: 0309217
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 192
    Time Indication: 0
    Date: 2010.03.23
    Time: 14:05:18
    Coding: 07024
    Shop #: WSC 06325
    Part No: 8E1959801B
    Part No: 8E1959802B
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 B
    Component: Dynamische LWR H01 0020
    Revision: 00000001 Serial number:
    Coding: 0000005
    Coding: 0309217
    1 Fault Found:
    Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
    Part No SW: 8E0 919 283 C HW: 8E0 919 283 C
    Component: Parkhilfe 8-Kan H06 0020
    Revision: 00H06000 Serial number: 00067802130435
    Coding: 0000114
    Shop #: WSC 131071 1023 2097151
    End
    2 fault code:
    -Incorrect VIN for clima (how can I re-code for new VIN, because I've change the clima)...
    -and fault code for telephone, but I don't have it in my car.
    I must set in vag-com (STG 56) no telephone ?
    Anyone who can help me ?
    Ashraf6119's Avatar
    UK
    After you have read the fault codes....... if you look on your right down you will see the option for (Clear Code) if you click on it you will see other Pop up click OK and it will clear the fault codes.
    And than start the car and see which codes are coming back.
    Hope This Helps
    Ash
    Hope This Helps
    Ash
    I've done Ash.
    The errors that come back are those of post #5...
    Thanks for help
    Ashraf6119's Avatar
    UK
    Since you have changed the HVAC Module which has a Vin Number from other Vehicle. I would just Ignore that fault code if the Vehicle is Running fine.
    For............01303 - Telephone Transceiver (R36)
    Have you checked the fuses and if it doesn't have this Option than again i would just ignore this as well.
    Ash
    I've change the klima module with another from other vehicle. All running fine !
    For telephone: in my car I don't have this option !
    Can I set in vag-com "no telephone" in STG 56 ?
    Best Regards
    Pasquale
    My friend all is ok now, I've set "no telephone" and the error is no longer reported.
    I've get a data learning and the VIN is ok for klima module !
    Now I have one fault code (this):
    Coding: 00000
    Shop #: WSC 00000
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    What's wrong ?
    In the car the klima work perfectly !
    Thanks and best regards !
    do not worry about this error, it does not affect the operation of HVAC
