Dashboard Audi A6 2003 year DEF
Results 1 to 7 of 7
    Mar 2010
    Eu
    40
    Downloads
    20
    Uploads
    Default Dashboard Audi A6 2003 year DEF
    I have problem with dashboard VDO , display show DEF.
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 933 G
    Component: KOMBI+WEGFAHRS. VDO D14
    Coding: 00040
    Shop #: WSC 25712
    WAUZZZ4B6xxxxx AUZ7Z0Cxxxx
    2 Faults Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    01304 - Radio
    49-10 - No Communications - Intermittent
    I need solution for this problemI need solution for this problem.
    Dump is in attachment , read from vag commander.
    Best Regards!
    Kusasusa
    Sep 2009
    8
    Downloads
    22
    Uploads
    You can write enclosed file by commander, readapt key and, then, synchronize ECU/dash. Next, change mileage by commander. The only difference is in software versions D14 / D15.
    Jan 2010
    K.Kambelovac Croatia
    5
    Downloads
    16
    Uploads
    You must change transponder chip in the key and adaption key
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    Downloads
    Uploads
    Quote Originally Posted by kusasusa View Post
    Coding: 00040
    Shop #: WSC 25712
    2 Faults Found:
    00-00 - -
    you have to replace the dashboard
    Sep 2009
    8
    Downloads
    22
    Uploads
    You don't need to change transponders in the keys and not change dash if you'll find correct dump.
    When you upload in eeprom the same version file or change with similar dash, first you release old data by entering old login according appropriate procedure. Then, using own login, you adapt dash to the your vehicle. Your 14th digit im*o code will be transferred into the dash. So, locked chips will recognize im*o.
    Check it in enclosed files. They are from the single dash insert.
    Dec 2009
    UAE Dubai
    Downloads
    Uploads
    Coding: 00040
    Shop #: WSC 25712
    2 Faults Found:
    00-00 - -
    01304 - Radio
    Best Regards!
    Kusasusa
    i need the photo of this kilo miter from outside
    and from inside showing the ic
    i need it very urgent
    can some one help me
    Aug 2019
    Downloads
    Uploads
    I have a same problem
