Results 1 to 8 of 8
Hybrid View
    Mar 2010
    Eu
    Default Dashboard Audi A6 2003 year DEF
    I have problem with dashboard VDO , display show DEF.
    Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
    Part No: 4B0 920 933 G
    Component: KOMBI+WEGFAHRS. VDO D14
    Coding: 00040
    Shop #: WSC 25712
    WAUZZZ4B6xxxxx AUZ7Z0Cxxxx
    2 Faults Found:
    65535 - Internal Control Module Memory Error
    00-00 - -
    01304 - Radio
    49-10 - No Communications - Intermittent
    I need solution for this problemI need solution for this problem.
    Dump is in attachment , read from vag commander.
    Best Regards!
    Kusasusa
    Sep 2009
    You can write enclosed file by commander, readapt key and, then, synchronize ECU/dash. Next, change mileage by commander. The only difference is in software versions D14 / D15.
  3. The Following User Says Thank You to Alex789 For This Useful Post:
    eeprom241 (9th April, 2022)
    Jan 2010
    K.Kambelovac Croatia
    You must change transponder chip in the key and adaption key
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    Quote Originally Posted by kusasusa View Post
    Coding: 00040
    Shop #: WSC 25712
    2 Faults Found:
    00-00 - -
    you have to replace the dashboard
  6. #5
    Sep 2009
    You don't need to change transponders in the keys and not change dash if you'll find correct dump.
    When you upload in eeprom the same version file or change with similar dash, first you release old data by entering old login according appropriate procedure. Then, using own login, you adapt dash to the your vehicle. Your 14th digit im*o code will be transferred into the dash. So, locked chips will recognize im*o.
    Check it in enclosed files. They are from the single dash insert.
  7. #6
    Dec 2009
    UAE Dubai
    Coding: 00040
    Shop #: WSC 25712
    2 Faults Found:
    00-00 - -
    01304 - Radio
    Best Regards!
    Kusasusa
    i need the photo of this kilo miter from outside
    and from inside showing the ic
    i need it very urgent
    can some one help me
  8. #7
    Aug 2019
    I have a same problem
  9. #8
    Oct 2020
    Montenegro
    hello, i have the same problem, which happened after replacing vp44. I followed the procedure, started the car without any problems. after a few ignition, this problem appeared, the instrument panel prints fuse and deff. when i read eeprom it was empty..what is the solution, does anyone have any file? the instrument cluster is vdo 4bo 920 933 gx .. Eeprom 93c86
