Renault Clio Diesel DELPHI electrical wiring
Results 1 to 15 of 20
    Elsewhere
    5
    Downloads
    33
    Uploads
    Default Renault Clio Diesel DELPHI electrical wiring
    Please I need electrical wiring injection DELPHI for a Clio 1.5 dCi, engine K9K ECU pins needed. I dl 2 DVD with Renault visu but found none I need.
    Thanks in advance.
    DK Veteran BeianM's Avatar
    Dorset UK
    28
    Downloads
    54
    Uploads
    Quote Originally Posted by alfabit View Post
    Thanks in advance.
    Look for a different model with the same engine if there is one.
    Elsewhere
    5
    Downloads
    33
    Uploads
    Looking, looking that visu but nothing, only K9K Delphi on CAN-diag, my car is KL-diag, so I'm still searching.
    Staffs UK
    Downloads
    Uploads
    I think you will find Delphi use Can and K line on ECU
    Plug/Pin/Colour
    CanH A/A3/White
    CanL A/A4/Violet
    KL A/B4 /Green
    Dorset UK
    28
    Downloads
    54
    Uploads
    All the info you need is in the bosch esi tronic. It is in the software section on DK.
    Take a look at the attached.
    Hope this helps.
    Elsewhere
    5
    Downloads
    33
    Uploads
    Do you somehow kwon the pin for information on " fuel debit " needed for the computer dashboard ? This is exactly what I'm looking for. Is a pin on the miidle connector but which one ?
    Downloads
    29
    Uploads
    Default ecu
    alguen tem esquemas de ecu estou presiando .
    Elsewhere
    5
    Downloads
    33
    Uploads
    Quote Originally Posted by joase tadeu ribeiro rocha View Post
    English please, por favor !
    Elsewhere
    5
    Downloads
    33
    Uploads
    nutloose,
    How do I open .mdi file ?
    Finally I succeeded.
    Asia
    Downloads
    Uploads
    Thanks in advance.
    Hi Bro!
    Do you managed to get your wiring diagram? Let me know if you still required the wiring diagram and ecu pin out for your car. I can obtain for you if you provide me with your VIN number.
    CheErS!
    Elsewhere
    5
    Downloads
    33
    Uploads
    I only want to know the pinout for " fuel debit " of a DELPHI ecu for engine k9k 792 1.5 dCi. It is a connection between a pin on the dashboard and a pin on the middle connector of the ecu. That's all I want to know, not all the wiring schematics, because I lack the fuel information ( debit, consumtion etc . ) on the dashboard. I have a hunch but I want confirmation. Thanks you all .
    Asia
    Downloads
    Uploads
    I could only find K9K 714/716 ECU pinout for "fuel debris" or "water in diesel" but if you can provide me more details like your Renault Clio VIN. I can provide you more accurate wiring diagram. I've attached a copy of K9K 714/716 ecu pin out, you might want to see if it applicable for your car. CheeRs and enjoy!
    FYI: I've circle the "water in diesel sensor" or Component Code 414 in red color for easy reference.
  13. The Following User Says Thank You to clearwhitesky For This Useful Post:
    capi (7th November, 2015)
  14. #13
    Downloads
    6
    Uploads
    I ned this also
  15. #14
    Downloads
    Uploads
    Default water sensor on fuel filter clio 1.5dci
    i am a new owner of clio 1.5dci k9k 714engine and i am interesting has anybody (maybe clearwhitesky) schematics for water sensor on the diesel filter(i want to eliminate that sensor because it is more difficult to find good filter with hole for sensor or only explanation (which contacts to short) on the sensor connector .pls send me on e-mail veljabob@yahoo.com
  16. #15
    Downloads
    Uploads
    Please need Renault Clio II ECU Schematics
