Results 1 to 5 of 5
    Oct 2008
    Default DM500 S Tuning issues
    Hi to everybody. I ma new in this formum .I have a DM500S with tuning issues. I have tried different immages but still not owrking. It has been working fine until September and then I have sent it back to the dealer that has confirmed to me that is nothing wrong but is only the LNB or something alse issue. The problem is that the signal is working fine with an old siver cros receiver. Can you help?
    Thanks Beppe71
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    There may be a difference in the strength of the tuners between the two receivers. Is it possible that your dish has been blown out of alignment slightly by high winds? Might need adjusting.
    Oct 2008
    Thanks, I changed the dish as well amd gone from 60 to 88cm. Yesterday I also tried to change the Twin LNB but still not working. I think is the immage of the DM500S, this is why I wanted try to dowload a new one from your forum.
    V.I.P. Member Curious123's Avatar
    Apr 2008
    The image will make no differnce to the signal, you really need to check as Devilfish that your dish is aligned correctly for the dreambox.
    Feb 2011
    Default Thank you for your information.
