Results 1 to 12 of 12
    Mar 2010
    south kirkby
    Unhappy peugout bsi or ecm problem / how to work planet propley as its new
    I am new to this lads i'v come a cross a problem on peugeot 406 2.0 hdi 04 plate none start park it up and come to it and it wont start. so called us in to diagnose the problem. all so customer orded a new chip and key as his centrial locking dont work fob u/s i syrenised the key to transponder and orange key waring ligth went from dash board still wont start i can start vehicle ok on easy start the ecu is locked by planet soft ware but im new to planet as its new to me iv a snap on modus 9.4 and ecu wont let it communcate.so iv tried to i went in on planet did globle scan and it brougth up
    u1- 12 volt no commucation
    13 pin 18 volt nr in 8221 controle module transponder .824 wier pin 6 on c001 connecter 16volt nr short to postive on 824 wier repair the harness also line goes up to front seat belt info 6301 and another line goes to 6440 reverse gear indexing diagnostic info can any one help please as iv put in the 824 wiering code in wiering looms data comes back not in the data base. its not wet in floor wiering loom not wet i have fuse box out bsi out carpet drivers side out but still wont start i have live from eng to bsi and 2 lives to ecu but no more could do with a wiering digram for this vehicle cheers
    Nov 2009
    Staffs UK
    If the car is left standing with a power drain so the battery goes flat without the BSI going to sleep it loses its memory.
    no VIN
    no Keys
    ?? doors
    ? etc
    when that happens you also cannot get comms with the engine ecu.
    check BSI configuration first.
    reset as required and add keys
    Mar 2010
    south kirkby
    Default bsi peugout wont work or start
    vin no vf38brhzf81635568
    build code 0980289
    engine rhz
    2.0 cc hdi
    04 plate 406 s hdi
    can say battrie never went flat just a none start
    done globle scan brougth up wats on first thread and its new chip windows work centrial locking dosent work for some time remotes broken orange key goes out on dash not shure how to get in to planet rto pair it all up thanks
    Mar 2010
    south kirkby
    the bsi box no
    valeo
    bsi var c cd4
    hw :3.0
    sw : 4.28
    ref valeo : 162 000 01
    ref psa : 96 509 144 80
    03/246/a
    Mar 2010
    south kirkby
    Default im reely stuck on on none start 406 20 hdi 04 plate peugeot
    13 pin 18 volt nr in 8221 controle module transponder .824 wier pin 6 on c001 connecter 16volt nr short to postive on 824 wier repair the harness also line goes up to front seat belt info 6301 and another line goes to 6440 reverse gear indexing diagnostic info can any one help please as iv put in the 824 wiering code in wiering looms data comes back not in the data base. its not wet in floor wiering loom not wet i have fuse box out bsi out carpet drivers side out but still wont start i have live from eng to bsi and 2 lives to ecu but no more could do with a wiering digram for this vehicle cheers [/QUOTE]
    Mar 2010
    south kirkby
    Default .dose any one know step by step to work the planet to match bsi box
    .dose any one know step by step to work the planet to match bsi box with thanks
    pro code 9802 d9 2001 406 20 liter hdi 04 plate
    Ashraf6119's Avatar
    Nov 2009
    UK
    1) Can you check on Dash if the Airbag Light goes OFF when you put the Ignition ON
    2) Do your Wipers and Front Lights come ON even if you DON'T Switch them ON when you put the ignition ON.
    Check This and report back here
    Ash
    Mar 2010
    south kirkby
    Default problems bsi
    hi mate
    i can switch head ligths on normle
    the head ligths come on when i unconnect couple connections on bsi box but go out when connected again
    air bag ligth gose out when switch engnition on
    nothing comes on if i dont switch them on thanks
    DK Veteran Albanais's Avatar
    Feb 2010
    Tirana
    Your problem stays on comm2000.
    It happens not very often but it happens that the cvv or comm2000 is faulty so this brings you to a faulty immobilizer and even worse you are not aloud to program new keys. So find one other comm2000 and replace it, i am sure that this will solve the problem
    Ashraf6119's Avatar
    Nov 2009
    UK
    To add with Albanais post also check the wiring under Driver side Carpet near accelerlator Pedal.
    Ash
  11. #11
    Mar 2010
    south kirkby
    Default bsi problem
    Quote Originally Posted by Ashraf6119 View Post
    Ash
    hi mate ihave carpets out and all dry floors dry wiring like new and No coreded harness
  12. #12
    Mar 2010
    Hi Pheonix, do you have comms with engine ecu.
    check in bsi peramiters go into immo check transponder recognised
    if no comms with engine check feeds earths
    double relay at ecu gives problems on these.
    ecu pins Ign off Ign ON
    A1 A2 B11 B12 0volt 0v
    B1 12v 12v
    B25 12v 0-1v
    B47 0v 12v
    B48 0v 12v
    B15 12v cranking (shut off valve)
    Hope this helps
