Hi all,
Can someone help me set up Orange 5 please.
I keep getting hardware error ATM.
Many thanks,
Jules.
Hi all,
Many thanks,
Jules.
Download the Orange 5 software from the official website
Install the software on your computer
Connect the Orange 5 device to your computer using a USB cable
The software will automatically detect the Orange 5 device
If the software does not detect the Orange 5 device, you may need to install the driver for the device
Once the Orange 5 device is detected, you can start using it
Make sure that you have the latest version of the software installed
Use a high-quality USB cable to connect the Orange 5 device to your computer
A hardware error at an ATM can be caused by a number of things, including:
A faulty component in the ATM.
A problem with the ATM's software.
A power outage or other problem with the electrical supply.
A problem with the ATM's network connection.
If you keep getting a hardware error at an ATM, you can try the following troubleshooting steps:
Try using a different ATM.
Try using a different card.
Try using a different PIN.
Wait a few minutes and try again.
Here are some additional tips for troubleshooting hardware errors at ATMs:
Make sure that the ATM is turned on and that the power cord is properly plugged in.
thanks_rep in i helped please
thanks in advance
Thanks for the help mate.
I should have said, the hardware error I am getting is "PS04" if that helps.
Also when I mention ATM, I meant at the moment sorry.
I have downloaded the software from the orange website but it is a rar file that is
needs a password. I have sent serial, hopefully I will receive the pass.
