Hello, If I do EGR OFF on Audi EDC17CP14. Will I have problems with the DPF regeneration?
There is no relation between dpf and egr if your dpf system is ok without any problems it should start regeneration without any issue ;;;; good luck
Knowledge is having the right answer...Intelligence is asking the right question...
Nitrogen Performance
Dont forgot Thanks and rep if i heled you ;
SKYPE : xxxxxxxxxxx
I ask, because in a Golf with PCR2.1, after EGR OFF, in the DPF regeneration, the exhaust temperature does not rise.
Because bad solution
If I helped you, click on reputation and thanks.
If you don't thank for help and give a reputation, you won't get help from me again.
You use my help at your own risk.
Mrpiston (27th July, 2023)
If egr is well disabled, then you have no problems with dpf.
Mrpiston (28th July, 2023)
Thats wrong. There totally is relationship between.There is no relation between dpf and egr if your dpf system is ok without any problems it should start regeneration without any issue ;;;; good luck
On the Golf (PCR2.1), I tried several solutions, without success.
And I bought the service of a well-known file modification company, with the same result. I consulted it, and they told me that there was no solution.
I realized, when forcing a regeneration, ODIS warns me that if the exhaust temperature does not rise, it could be from the EGR.
My question is if it is the same with EDC17CP14?
Master Alientech
Master DFB Technology
File Service
Mrpiston (30th July, 2023)
For pcr2.1, mrpiston is talking about
ip_tqi_egr_di_norm_X
ip_tqi_egr_ena_norm__X
to zero, i think.
With this no problem with regneration.
For CP14 often Problem is that with disabled egr you will not create enough engine temperature (water temperature dont raise enough) to work with dpf regeneration.
Mrpiston (6th August, 2023)
