Results 1 to 10 of 10
Hybrid View
    Jun 2014
    Default EGR OFF EDC17CP14. DPF Problems?
    Hello, If I do EGR OFF on Audi EDC17CP14. Will I have problems with the DPF regeneration?
    youfarid's Avatar
    Dec 2020
    GAZA
    There is no relation between dpf and egr if your dpf system is ok without any problems it should start regeneration without any issue ;;;; good luck
    Knowledge is having the right answer...Intelligence is asking the right question...
    Nitrogen Performance
    Dont forgot Thanks and rep if i heled you ;
    SKYPE : xxxxxxxxxxx
  3. The Following 2 Users Say Thank You to youfarid For This Useful Post:
    MRAWZIN (26th July, 2023), Mrpiston (27th July, 2023)
    Jun 2014
    I ask, because in a Golf with PCR2.1, after EGR OFF, in the DPF regeneration, the exhaust temperature does not rise.
    Nov 2016
    Because bad solution
    If I helped you, click on reputation and thanks.
    If you don't thank for help and give a reputation, you won't get help from me again.
    You use my help at your own risk.
  6. The Following User Says Thank You to Stopro92 For This Useful Post:
  7. #5
    Jun 2014
    Quote Originally Posted by Stopro92 View Post
    Can you explain something else? What is the good solution?
  8. #6
    Nov 2016
    If egr is well disabled, then you have no problems with dpf.
  9. The Following User Says Thank You to Stopro92 For This Useful Post:
    Mrpiston (28th July, 2023)
  10. #7
    May 2017
    Thats wrong. There totally is relationship between.
  11. The Following User Says Thank You to Lambda1 For This Useful Post:
  12. #8
    Jun 2014
    On the Golf (PCR2.1), I tried several solutions, without success.
    And I bought the service of a well-known file modification company, with the same result. I consulted it, and they told me that there was no solution.
    I realized, when forcing a regeneration, ODIS warns me that if the exhaust temperature does not rise, it could be from the EGR.
    My question is if it is the same with EDC17CP14?
  13. #9
    Luigi84's Avatar
    Dec 2022
    Italy
    Quote Originally Posted by Mrpiston View Post
    there is a solution EDC17CP14 ,you can do egr off correctly to keep dpf but you can only do this if the egr is working and without problems because during the regeneration the egr goes into operation,when the car does not regenerate it goes back to egr off
    Master Alientech
    Master DFB Technology
    File Service
  14. The Following User Says Thank You to Luigi84 For This Useful Post:
    Mrpiston (30th July, 2023)
  15. #10
    May 2017
    For pcr2.1, mrpiston is talking about
    ip_tqi_egr_di_norm_X
    ip_tqi_egr_ena_norm__X
    to zero, i think.
    With this no problem with regneration.
    For CP14 often Problem is that with disabled egr you will not create enough engine temperature (water temperature dont raise enough) to work with dpf regeneration.
  16. The Following User Says Thank You to Lambda1 For This Useful Post:
    Mrpiston (6th August, 2023)
