Results 1 to 1 of 1
    Jan 2016
    Default w204 headlamp coding
    w204 2012, with ILS, xenon on low beam, halogen on high beam. There is an automatic high beam. instead of xenon put Chinese led lamps, the camera on the windscreen is also absent. in block HLC166 3 errors, on the camera and on 2 xenon lamps, and does not work high beam. how to code through vediamo without ILS, so that the high beam was switched on from the handle? or how to remove the polling of xenon ignition blocks?
    codings attached
