Another update guys I got correct files from another good same type working dash..but after writing it to my cluster the cluster still same story..
So I think dash is dead or stuck in boot mode
Sent from my SM-A226B using Tapatalk
Guys I'm getting replacement cluster so il need programme it I have VCM2 I'm trying to get online ids software..can some1 tell me how to doit please?
Hi check this forscan I got extended license I have scanmatik pro2 interface..iv tried contacting to the car it connected good check bellow pic..
Now with forscan finds the cluster but says " no diagnostic function"..I tried to load the factory as built in data but i get an error
So I'm not sure if the cluster can be fix..or must I get replacement one?
Guys just updating you guys about the ford ecosport 1.5TDCI cluster...
Well I got replacement from same type & you know what????...I read this replacement cluster & the files sizes are different..remember its same typ vehicle & eeprom size is 2kb not 4kb..
All files iv tried from this forum & everyone else was 4kb not 2kb..but my dash eprom is 2kb.thats why iprog failed to do mileage correction
So I Have the replacement cluster & trying find way to program it..
Iv loaded the replacement cluster 2kb eeprom on original cluster & the cluster came alive again..can you believe it?!!
Guys Im having problems trying program this replacement cluster..
Please can some1 share ecu & dash set files?
This vehicle is stressing me out
Can ecu & Replacement cluster dump be sync by dumps?
Because we managed programming the keys but ecu & dash file to syncro...
Immo off possible?
Problem solved
Thanks goes to Hamza who help me doit in 10mins
pawl (17th August, 2023)
Troco5773 (21st May, 2024)
