Results 1 to 2 of 2
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    Default IX 35 4WD problem.
    Hi , i have problem with 4WD Hyundai IX 35
    year 2010
    system Jtekt nr.95447-3b100
    engine 2.0L - D
    4WD not working even if press LOCK ... Only front wheels spins
    But i measure on coil i have 2,5oHms.
    But when i measure volts on coil pins nothing go here from 4WD computer
    I make diag on 4wd computer but no fault , nothing,
    Can be bad 4wd computer not sending power to coil?
    How much volts sending on coil ?
    Have somebody diagram (pinout) from 4wd computer ?
    Thanks.
    Feb 2021
    Possible 4WD module is protecting 4WD clucth as temp is too high,
    before changing clutch, you need to check following,
    -max difference 2.0 mm in tyre tread depth between all tyres
    -compare all 4 ABS sensor while driving
    -make sure no comm faults in 4WD module (U CODES)
    -check connection to 4wd clutch 12V PWM Signal
  3. The Following User Says Thank You to IanBMW For This Useful Post:
    Junkyard Dog (21st August, 2023)
