Results 1 to 5 of 5
Hybrid View
    Jul 2009
    EASTERN AFRICA
    Default Need good dpf off Crafter edc17c54
    Hi all
    After dpf delete car don't have power, no light no dtc but car does not rev over 2500rpm, could anyone check if file is ok or wrong? thank's a lot
    vw crafter 2,0tdi edc17c54 CKTB
    Jul 2016
    FRANCE, 22
    Hello can you post ori file in this ecu it's a switch to turn dpf off
    Thanks + rep for pass
  3. The Following User Says Thank You to Lusitano94 For This Useful Post:
    sokolomo (9th August, 2023)
    Jan 2021
    Netherland
    Post orignal file, so we can provide correct solution
    .... File service ....
  5. The Following User Says Thank You to wjgud123 For This Useful Post:
  6. #4
    May 2017
    If car after dpf and software dont have power, the file will be the issure pretty sure (if also no error present, sensors disconnected...).
  7. The Following User Says Thank You to Lambda1 For This Useful Post:
  8. #5
    Jul 2009
    EASTERN AFRICA
    my problem is that i received engine ecu( second hand) with the dpf already deleted, there were many faults such as the electric water pump, injector fault which have already been rectified but always limp home mode
