Results 1 to 14 of 14
    Aug 2023
    Default Mercedes Sprinter CRD3 kess write problem.
    Hello everybody, i need help please , i read a Mercedes Sprinter , i used kess v2 2.80 , the read was sucess , but the write of the remaped file at 100% an error happened , the write was a fail , i was unable to restore ECU with kess by obd.
    I will post the original file and id.
    I am worried that the read file is currupt , can someone see if that is the case please ?
    I only want to make the car stock at this point by restoring the file by obd with kess.
    I dont want to risk damaging the ECU with ktag Boot mode tricore.
    At this point i am unable to read the id.
    The remap file that i atempted to write was only dtc removal , the checksums were corrected in winols.
    I want to solve this issue , and in the future help other people in this forum.
    All help is welcome.
    Thank you.
    Aug 2023
    The car does not start
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    You never must do checksum for KESS writing. This is your mistake.
    And your archive is damaged.
  4. The Following User Says Thank You to Inquizit0r For This Useful Post:
    John900 (30th August, 2023)
    Aug 2023
    Hello thanks for the reply , can you give me the ori file for the ECU ?
    I need to recover the ECU.
    Thanks for the reply.
    Aug 2014
    attach your read again cause rar is damaged.. try zip
  7. The Following User Says Thank You to lsdlsd88 For This Useful Post:
  8. #6
    Aug 2023
    Aug 2023
    Thanks for the reply , i posted a link for download of id and read.
  10. #8
    Aug 2023
    I forgot to say , i used a special protocol , because the tool is clone , there was no specific car , so i used the following protocol. I Will post photo.
  11. #9
    Aug 2014
    your read is OK and 100% ori. can u try writing using recovery function?
  12. The Following User Says Thank You to lsdlsd88 For This Useful Post:
  13. #10
    Aug 2023
    I tried recovery but an error ocorrs during recovery , and the software kess , keeps asking if i want to recover , but every time ir does error.
  14. #11
    Aug 2014
    battery on/off too ? if that doesnt write it then u have to use bench / boot tools for sure
  15. The Following User Says Thank You to lsdlsd88 For This Useful Post:
  16. #12
    Aug 2023
    Batery stabilizer was used , and followed kess instrucions on ignition on and off.
    I have ktag but i AM afraid to Open and tricore Boot mode recovery , afraid to ruin the ECU.
  17. #13
    Aug 2014
    i mean take battery negative OFF and then back ON to reset all modules. then try write again. boot tricore is not hard but if you're a beginner its easy to make mistakes. bring to someone with experience maybe they have genuine tools to work via bench without opening
  18. The Following User Says Thank You to lsdlsd88 For This Useful Post:
  19. #14
    Aug 2023
    Thank you for your help , i Will try the batery and recovery , if not work , the i Will take to other people to Open on beach.
