Hi all,problem with my 2009 Cio mk3 1.2.
The window washer pump isn't working,fuse is ok,pump is ok, steering column switch is sending out signal,bcm is receiving the signal,but the BCM i don't think is sending out a signal to the washer pump.
I say i don't think as i don't have a definitive wiring diagram telling me which colour the wire coming out the bcm to the washer pump should be.
Anyone have a diagram of wire colours for a bcm for these?I've just been randomly testing every wire with a test light coming out the bcm while activating washer pump switch,none have lit up.
Anyone help?
