Results 1 to 2 of 2
    Default Airbag ECU Coding for Touareg
    Hi Bros,
    The touareg is crashed, and I replace an used airbag ECU. After replaced the ECU, I see code 01044 - Control Module Incorrectly Coded.
    How to code the control module correctly?
    Thanks for help.
    Ashraf6119's Avatar
    UK
    Your best bit is to read the software code from the old module.
    But if you are using Vag-Com than it should give you some Options for the software Coding.
    Have a look in this link
    VW Touareg (7L) Airbag - Ross-Tech Wiki
    Hope This Helps
    Ash
