Results 1 to 5 of 5
    Czaku's Avatar
    Sep 2021
    Default Passat B5 1.8 AGR Software Coding Issue
    Passat B5 1.8 AGR
    Manual gearbox
    ECU: 8D0 906 018R
    Current Soft. Coding: 04001
    DTC: 18020 - Engine Control Module Incorrectly Coded
    Hi Team,
    I have problem with Passat B5 after replace ECU.
    Previous ECU dead and car doesn't work. I have new, the same ECU without IMMO.
    The car starts, but I have the error as above.
    I can't comunication with orginal ECU so I can't read correct Soft. Coding.
    VCSD does not suggest an coding method.
    Can anyone help with correct coding and a login to change the coding?
    Thanks in advance.
    You can't treat a car like a human being. A car requires love.
    Keep in mind, English is not my native language.
    IF I HELPED YOU, PLEASE REMEMBER TO PRESS THANKS AND REPUTATION.
    kiszka's Avatar
    Quote Originally Posted by Czaku View Post
    Passat B5 1.8 AGR
    Manual gearbox
    ECU: 8D0 906 018R
    Hi Team,
    Thanks in advance.
    read the eeprom of the old ecu and insert it here
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
    Czaku's Avatar
    Sep 2021
    EEPROM what I found is ST950403. It is correct?
    Unfortunately I have no posibility to read.
    I wonder if resoldering these memories will solve the problem.
    kiszka's Avatar
    Yes, desolder it and read it with a programmer
    Reality of life :
    4:Everyone lies
    Czaku's Avatar
    Sep 2021
    I think we misunderstood each other.
    I do not have a programmer to read this EEPROM model.
    I asked if resoldering this memory to the new ECU could solve the problem.
